Hi all,
I've been doing a lot of investigation into leaks and think I have found a major culprit. This is the drivers-side door and clearly it looks as though the window has closed too far and/or the quarterlight is sitting too low. I sat in the car while my wife sprayed it with the hose sure enough it was pouring in from this point.
With how the window sits against the roof seal, I am inclined to think the quarterlight is set too low in the door - is this adjustable? And does anyone know the name or part number for the torn rubber cap on the end of the window runner?
Thank you
Thank you
