As above , the screw that retains the metal cover and plastic pipe guide has snapped off when trying to replace.
Anyone had this happen and how did you get over the problem, rather not try the map gas so close to the fuel pipes!
Not sure why they use such small fixings underneath the car that are obviously going to rust ? Trouble is the fitting the screw is corroded into is pretty flimsy so isn’t going to take to much pressure before that’s damaged as well!
