Thank you. Will give that a go.You can reset the light on dash with a piece of wire.
View: https://youtu.be/-UZP471VLiY
I have a c110 but couldn't tell you if it will reset the light.
Thanks for your help.Your code reader will clear codes and do resets, the option to do that will be in the menu for the module that you are scanning, if you don't have any instructions book with it have a look on Youtube for C110+ scanner there are how to videos on there.
I always do it this way, takes no time, about 20 secs probably much quicker than connecting the reader and searching the menusYou can reset the light on dash with a piece of wire.
