Sensors
billz
Langley Mill
Hi all i am after changing the sensors on the zed, i have changed the Exhaust one already due to this failing and have decided to replace the other sensors. I am after the part numbers for the other sensors that i can change ie lambda, inlet i have had a look but typical realoem call them pulse sensors ping sensors and i cant find any for the lambda. All help greatly appreciated.
bill
Titan
Moderator
North North Yorkshire
sDrive35i
Unless I am mis-understanding you Bill, the exhaust sensor is the lambda sensor.
The others you mention are cam position sensors which are known as pulse sensors.
This diagram may help.
billz
Langley Mill
Thanks terry
I have looked at the diagram and i have changed No2 I take it i need to replace No3 but what is No7 I take it No1 is just a variant of No2 but with the lead attached.
Do you know what the part number for the MAF sensor is as i couldn't find it. All the Lambda sensors i have found on line look completely different to the ones in the Diagram
thanks
bill
Titan
Moderator
sDrive35i
If you know the last 7 digits if your VIN number I'll do a specific search for you. (PM them if you don't want to publish them on open forum)
Sent from m'iPhone using TappetTorque
Jamezee
Peak District
2.2 sport
Hi Bill,
I have no idea about sensors but just thought I would say hi :-h
billz
Langley Mill
Hi Dave. About time we had a run out and meet up. Terry i will PM you the vin Number. Thanks
bill
Titan
Moderator
sDrive35i
Got your PM Bill.
Try this lot - hope it helps:
Lambda Sensors (#1 & #2)- http://www.realoem.com/bmw/showparts.do ... g=11&fg=50
Cam Sensors (#1 & #2) & Crankshaft Sensors (#3) - http://www.realoem.com/bmw/showparts.do ... g=12&fg=05
No idea what #7 is - sorry :(
MAF sensor (#1) - http://www.realoem.com/bmw/showparts.do ... g=13&fg=15
Jamezee said:
Hi Bill,
Hi Jamezee
Now just skip along, eat your shepherd's pie and stop hi-jacking this sensitive topic :baa
Aceman
Moderator
Wakefield
///M Roadster
Number 7 is the knock sensors which bolt to the engine and detect pre-ignition or PINKING which Terry knows all too well what that is in a Z3. ;)
Topperz
Swadlincote / ashby de la zouch
Z3 cosmos black ltd edition
Pinking ??.
That's the term used for daytime dogging during the summer when the suns out
Or in my case driving round with the top down in the summer with no hat on
:D :coolsteer)
Topperz
