Sensor Cluster 01(Yaw Sensor)
Layor
Llandrindod Wells, Powys
Z4 SDrive 23i M Sport 2.5Ltr. H.T Convertable
Hi all,
Does anyone happen to know the six pin outs for the Sensor Cluster 01, the Yaw sensor. I have managed to get the circuit board out and checked the S.M. components as far as I am able. There does not appear to be any faulty components, the diodes, caps etc are giving readings which I would expect but it would be helpful to have either a circuit diagram or at least the pin configuration.
I have had a look for diagrams on the web, but although there are some there for other units I cannot find one for the '01' sensor. The part number is: 34.52-6 759 412.
This is more of a curiosity project than a repair job as the replacement I bought from ebay for £24 is working well and has solved my problems. It hardly seems worth messing around with but it's an itch that needs scratching!:mad:
Cheers, Colin.
Brian4
Near Grantham
Z3 3.0i Auto
Hi all,
Cheers, Colin.
Not sure on wiring diags but that part number is from a Mini.
http://www.realoem.com/bmw/enUS/partxref?q=34.52-6+759+412.&series=JCW
But must be similar to the Z4 one
http://www.realoem.com/bmw/enUS/par..._30i&mg=34&sg=20&diagId=34_1289&q=34526764018
Layor
Hi Brian,
Yes, there are a few bits, electronically, that appear to fit both the Mini and the Z4. The sensor I bought to replace the old one did give a few models it would suit, including the Mini, and as the part numbers matched and it solved my problem all is well!
I took the 'Zed' for a spin yesterday over to my sons in Worcester, about an hour and a half, never missed a beat and purred like a panther there and back!
Colin.
