Can't get rear inboard 17mm bolt out. Having trouble. any ideas?
The socket can't grab enough of the top. Spanner gets even lesstry open end spanner?
I don't want to round off the edgestry open end spanner?
I got the 4 bolts, 2 nuts, 2 bolts off the driver's seat, Tried to disconnect the wire harness. The big one came apart but the small one didn't. I couldn't see how it worked so I started to take off the pass. seat to see if I could get a better look at it and/or get it off. Can't get that fartry open end spanner?
Tried that. but that seems to be the best bet. I'll use a bar or large screw driver as a wedge.to move it. might give enough room to allow the socked to get a better grip.yes i understand that but if you get the bolt loose by moving the chair it should work ;-)
Yeah, I know, but I only have the rest of today and tomorrow to work on the new top. I can't even get to the top yet.agghhhhhbe patient with it Frankie, she will come ;-)
That's what I was looking for. Out to the car now.i wonder if the guys who had the seat bush replacement day had a tried and tested method?
Couldn't quite move the seat over. Could probably do it if I knew the right way. I'll think of something or some one will have a good idea. Also, I need to know how the small connector comes off. By the way, have a 96 z3.good luck my friend ;-)
Does any one know of a way to move the seat track over. I have to center a rear track bolt that's not centered in its recess. If you've done seats before, you'll know what I'm talking about. FrankieCouldn't quite move the seat over. Could probably do it if I knew the right way. I'll think of something or some one will have a good idea. Also, I need to know how the small connector comes off. By the way, have a 96 z3.
