Z3Mroadster
- Joined
- Nov 24, 2013
- Points
- 50
Driver seat squeak when I sit and drive.
What is problem?
What is problem?
It's your M telling you to shed a few poundsDriver seat squeak when I sit and drive.
What is problem?
What bolt?Position?Mounting bolt loose, frame or mounting point cracked?
There are supposed to be 2 nylon clips in there which are presumably to stop the squeaking.I have m seats in my 2.8 and I had a squeak not sure if this was the cure, I removed the seats to do the bushes as I had a very slight rocking movement but I found the bushes to be as new, when I looked further I found movement on the 2 hooks from the frame to the seat, the gap was about 1.5mm. I filled it with a nylon applicator this stopped the rocking and squeak
Really, I never knew thatThere are supposed to be 2 nylon clips in there which are presumably to stop the squeaking.
Pictures?There are supposed to be 2 nylon clips in there which are presumably to stop the squeaking.
I’ll go and remove a seat now for you...Pictures?
Yes, seat out and base off, you don't need to disturb any of the leatherIs it necessary to disassemble the seat?
