JeffC
So I thought I would crack through the jobs on the new purchase starting with fitting seat bushes as it was moving badly under braking, all pretty straight forward to do as instructional videos I had watched on you tube .
after assembly tried seat back and forth and it moved. so refitted then wound the seat right forward to get the rear bolts back in , when I tried to put the seat back it has jammed , motor is trying to move but its having none of it. I managed to get the seat back out and with the wiring connected its doing the same, I can only presume the bush has snagged on the threads.
Problem is I now cant take it apart again to check the bush as I need the seat in the back position to get at the T50 torx bolt , Ive tied running some oil down the threads which hasnt helped.
Anyone come across this before ?
Thanks.
Thanks.
