Likely to be more than that, plus the other side too. Best thing to do is remove the seats, carpets and console to get it dried out thoroughly.Just done the seat bushings on the passenger seat today, much easier than expected. Only issue is there must be 10 litres of water in the insulation under the carpet
It's garaged and I only use it when its not raining, only had it since February, I know it leaks a little from the back window I'll get it dried out. Probably put a new roof on next year.Better find and fix the water leak, or you'll be back redoing the job sooner than you would like.
That's why I said I only had it since February, its probably been damp for ages and most definitely used in the rain.“only had it since February” , does that mean it has never ever been used out in the rain for its whole life. Those floor carpets won’t dry out by themselves so could have been wet for a long time.
Correct. Till you get the carpets out you won't realise how thick they are. Seriously. In the footwell there's, like, 2 inches of foam backing. If the surface of the carpet has water on it then you've got a gallon or more water in there. That'll never dry out on its own........... Those floor carpets won’t dry out by themselves so could have been wet for a long time.
I've lifted the carpet and it's only the foam that is damp, I've had a blow heater on the rear section all day and it's now dry, lifted and propped the front and now drying. I got the majority out by extraction first.Correct. Till you get the carpets out you won't realise how thick they are. Seriously. In the footwell there's, like, 2 inches of foam backing. If the surface of the carpet has water on it then you've got a gallon or more water in there. That'll never dry out on its own.
