nats_swims88
- Joined
- Oct 16, 2022
- Points
- 3
Hi all, we need the clips that hold the seat belt to the seats as both have snapped.
Quite a big repair is this as you need to remove the upper seat covering to access the clips from the inside.Hi all, we need the clips that hold the seat belt to the seats as both have snapped.
IT God mate
Mine too are cactus, furthermore they have been cactus under the seat covers for long enough to damage an otherwise fantastically preserved seat. My solution is a bit different from others I have found and does not require the removal of the seat. Just a little bit of creative patchwork that also hides the damage caused by the broken clip. If I pull it off as I expect it should look good too, and be repeatable if it happens again...Hi all, we need the clips that hold the seat belt to the seats as both have snapped.
There are several ways to repair this problem, as well as replacing the plastic guide just google it.Mine too are cactus, furthermore they have been cactus under the seat covers for long enough to damage an otherwise fantastically preserved seat. My solution is a bit different from others I have found and does not require the removal of the seat. Just a little bit of creative patchwork that also hides the damage caused by the broken clip. If I pull it off as I expect it should look good too, and be repeatable if it happens again...
Well I did it, for the cost of a coffee. Its a bit agricultural but it works and they are stronger than new ones.. took me ten minutes a side..My local upholstery shop installed my new ones. Quite cheap and done properly. I bought the clips off eBay
