Hi all,
Issue is happening on an E36 M3 Evo for context - apologies, I know this is a Z car forum. I have uploaded this post onto m3cutters, but wanted to open up the chances of getting to the bottom of this issue. Hope this is OK.
I've had my car for 10 years now, and in all that time it's had an issue where under certain conditions, the engine cuts out. The issue only happens when it is a hot day, say about 25 C or warmer (engine temp plays no part in the issue though) and only when under heavy throttle/WOT. The RPM it happens at varies, but I'm pretty sure it always happens over 3k RPM. Over the years I've replaced a few bits chasing the issue - fuel pump, fuel pump relay, knock sensors, and probably more that I've forgotten about. I've also obviously done service items including fuel filter which was last done less than 12 months/1k miles ago. It's been plugged in many times through INPA, DIS, and iCarsoft CR Pro - no codes present for the issue whatsoever. I have been chasing this issue for quite some time although has been on the backburner as it only happens in hot weather. Steve at MrVanos has also looked into it for me when I took it there in 2014 for other work but was unable to find anything at the time.
I've narrowed the issue down to the fuel pump losing 12v power supply. I've verified this by cutting back the sheathing on the fuel pump power supply wires under the rear seats and soldered in two wires running to an LED which I can see from the drivers seat. When the fuel pump has power, the LED is illuminated and when the engine cuts out, the LED goes out. When the engine cuts out I don't lose electrics to anything other than the fuel pump. Lights, radio and all the other instruments still work normally - it just feels like I've hit a rev limiter or lifted off the throttle, but my foot is still firmly planted on the throttle. If I dip the clutch, the revs drop to 0 RPM. I then obviously need to coast the car to the side of the road safely (which can be pretty hairy depending on the situation!), switch off the ignition, wait 10 seconds (that seems to be the time that you need ignition off before the fuel pump will prime again before starting) and start the engine again. Car fires up like nothing happened and runs perfectly again. The car drives faultlessly the rest of the time, makes good power, idles smooth, no funny noises or anything untoward.
I watched the YouTube video from Evolve Automotive where Steve @ MrVanos, appears to talk about the Vanos on these engines:
Skip the video forward to 14 minutes and he starts to talk about the issues with solenoids, but specifically at 14:20 he talks about the diodes in the plugs which can go bad and cause issues, he even mentions that he's seen failed diodes 'trigger the fuel pump'. This led me to do a bit of research about what diodes do and how to test them. I understand that diodes are essentially like a one way valve and protect components from a reverse pulse. That means failed diodes in the vanos plugs can send a reverse pulse to the DME, hence leading to the strange electrical issues like Steve explains in the video above.
This video is very useful and talks about replacing the diodes and shows the wiring diagram of the plugs (1:45 onward) and a photo inside a plug after dismantling it (4:25 onwards).
I believe this video was created by @Pingu - any help you can provide would be greatly appreciated.
Yesterday I disconnected the plugs to both inlet and outlet vanos solenoid units and attempted to test the diodes (forward biased) in the connectors plugs by using a multimeter's diode testing mode - negative lead to the cathode (which is connected to the two outside pins of the plug) and positive lead to the anode (centre pin). I got a reading (voltage drop I believe) of 0.003 over all 4 diodes. I then switched to reverse bias, so negative to anode and positive to cathode and got the same readout of 0.003 across all 4 diodes. I presume these readings means all 4 diodes are shorting and therefore need replacing? Either that or I'm doing something wrong/my multimeter isn't functioning correctly. The multimeter does read 1 when the positive and negative aren't connected to anything and it reads 0.000 when I touch them together which implies the multimeter is working as it should. If the diodes were dead, it seems strange that the car runs normally in cooler temperatures - I believe temperature does affect the flow of electricity, but that's all a bit over my head. I'm by no means an expert when it comes to electronics, so apologies if any of that wasn't clear or I used incorrect terminology.
To summarise:
1. Given the results from testing the diodes, does it look like my diodes are dead (and potentially causing this issue) or could I be using my multimeter incorrectly and barking up the wrong tree?
2. Can I remove the solenoids on the car without removing the whole vanos units and if so, what's involved to dismantle and re-assemble - are there any good DIY guides? I assume I'll need to let out the pressure from the oil lines and bleed it when re-assembling.
To summarise:
