S50 Z3M Pearlescent Journal
Discussion in 'Progress Threads' started by Lee, May 30, 2014.
  1. Lee
    Lee Zorg Guru (V)
    British Zeds #ZedShed M Power
    Mar 26, 2014
    2,839
    3,555
    182
    Model of Z:
    Z4 Coupe
    Wish me luck guys. My car is in pretty good shape other then an annoying rattle located on top of my fuel tank.
    This weekend i'm taking her off the road for a couple of weeks to remove whole rear end and drop the tank.
    While im under there i will be replacing all the bushings and couplings for goodmeasure.
    I will get a few pics up along the way and keep you guys posted. Here are some teaser photos for a guy who did it in the states.
    • Like Like x 6
    • Thank You! Thank You! x 1
  2. t-tony
    t-tony Zorg Expert (I)
    Supporter British Zeds
    30,206
    14,252
    220
    Model of Z:
    Z4 3.0 Auto
    That looks like a proper job done. Reminds me of a spitfire chassis I rebuilt many moons ago. Had to go to finance buying the plot where we have lived for 34 years. To quote Jim " That's when the fight started" :)
    • Like Like x 1
  3. EnthuZiaZT
    EnthuZiaZT Zorg Guru (V)
    British Zeds East Anglian Crew
    Dec 6, 2011
    4,567
    2,181
    193
    Heacham Norfolk
    Model of Z:
    Z4 28i Msport
    Wow! Lee that looks awesome. When you've finished can you come and help me do mine?
    Thanks
    Mike
  4. Aceman
    Aceman Moderator
    British Zeds 3rd Party Trader
    2,204
    707
    156
    Wakefield
    Model of Z:
    ///M Roadster
    I would be wary of doing the the swing arm bushes with poly ones as they are known to start squeezing badly after a few hundred miles so best sticking with eom for those.
    I would love to do this too sometime so would be grateful if you would post up some pics and a little writeup.
  5. Lee
    Lee Zorg Guru (V)
    Mar 26, 2014
    2,839
    3,555
    182
    Model of Z:
    Z4 Coupe
    I agree about the poly bushes. It will put to much strain on the rest of the car so OEM is where i will stay.
  6. Lee
    Lee Zorg Guru (V)
    Mar 26, 2014
    2,839
    3,555
    182
    Model of Z:
    Z4 Coupe
    Quick update,
    Last night I finally gave up and repaired my existing fuel tank. (Long story) Once in "which was quite fiddly" the axle followed. Picture shows its cleaned state. Tonight’s jobs are to torque every nut and bolt then test drive.
    • Like Like x 1
  7. swamper
    swamper Zorg Guru (V)
    Supporter M Power
    Dec 4, 2011
    2,589
    801
    181
    Mossley
    Model of Z:
    z3m
    brave...keep us posted im watching with interest
    • Agree Agree x 1
  8. Lee
    Lee Zorg Guru (V)
    Mar 26, 2014
    2,839
    3,555
    182
    Model of Z:
    Z4 Coupe
    Its all back together mate, Used it this week for work. Only need to adjust the hand brake cable as its rattling a little.
    Read the Step by step article Swamper.
    Hope you all find this useful. Next job is my Vanos overhaul.
  9. t-tony
    30,206
    14,252
    220
    Model of Z:
    Z4 3.0 Auto
    :thankyou:Hi Lee, please show the Vanos job in as much detail if possible. It would be very interesting, thank you, Tony.
  10. Lee
    Lee Zorg Guru (V)
    Mar 26, 2014
    2,839
    3,555
    182
    Model of Z:
    Z4 Coupe
    This job may take a little longer. I'm planning on going through it and may alter things. If i do it will be an in-depth article.
    • Like Like x 2
  11. Lee
    Lee Zorg Guru (V)
    Mar 26, 2014
    2,839
    3,555
    182
    Model of Z:
    Z4 Coupe
    Little update. I made a temp repair on the fuel tank so i can fix it at a later date. This was done at the start of summer. Ideally i need a new fuel tank.
    So far this year i have done the following:
    2x Full service's
    2x sets of tyres (Falken 453's)
    Wheels spacers (20mm rear 15mm front)
    Re wrapped the front bumper and mirrors
    Carbon ariel
    Hardtop plus fitting kit
    Refurbed all four seat motors (from home)
    New stereo (Alpine)
    Stormworks gearknob/handbrake
    Replaced boot tools
    I also found airfolow problems a few weeks back, only to find half a pigeon in my intake and a very blocked filter. I even had a fern cone in there. I'm thinking this has been my problem since getting back from Le'mans earlier this year.
    Pictures to follow.
    Titanium finish.
    This is how she sits at the moment.
    Plans for the coming year.
    Slight warped front disc (front Black Diamond discs)
    In the coming weeks my hardtop should be wrapped to match the car
    New kidney grills
    Custom designed LED halos
    Seats need some TLC
    VDO guage reading the temp needs a new sensor
    Lee Out.
    #11 Lee, Dec 9, 2014
    • Like Like x 2
  12. GazHyde
    GazHyde The Gaz Monkey
    Dec 2, 2011
    15,111
    9,173
    Newbury, Berkshire
    Model of Z:
    BMW Z4 3.0Si Sport
    Everyone needs a bit of Storm Motorwerks in their Zed :)
    • Agree Agree x 2
  13. Lee
    Lee Zorg Guru (V)
    Mar 26, 2014
    2,839
    3,555
    182
    Model of Z:
    Z4 Coupe
    Small update, Added some halo rings. These are the 131mm LED rings. You need to shorten the inner ring to fit. Comes with a remote choose your colours etc.
    • Like Like x 6
  14. g8jka
    g8jka Zorg Guru (III)
    1,873
    1,165
    148
    Telford, Shropshire
    Model of Z:
    Z3 - 2000 2.8 Roadster
    Looks good Lee. Did you mange to get them to fit ok behind the lenses? I found that the white setting started to look more of a blue colour after the car had been running for a bit. They are pretty bright though!
    • Like Like x 1
  15. Lee
    Lee Zorg Guru (V)
    Mar 26, 2014
    2,839
    3,555
    182
    Model of Z:
    Z4 Coupe
    Yeah thanks @g8jka I trimmed 6 LED's on the inner rings. The rings sat perfectly against the lense with the help of some gorilla glue.
    Yeah they have gone a little bluey, I turned the bightness down a little and all is well.
    • Like Like x 1
  16. Aceman
    Aceman Moderator
    2,204
    707
    156
    Wakefield
    Model of Z:
    ///M Roadster
    You got a link to the supplier of these Lee (ebay?). Always fancied fitting halos but been put off with the unreliability of flourescent tube ones so these seem a good alternative. Any chance of a close up shot of the headlight in daylight without them switched on just to see how obtrusive or unobtrusive they are behind the lenses when not switched on.
    Cheers
    • Like Like x 1
  17. Lee
    Lee Zorg Guru (V)
    Mar 26, 2014
    2,839
    3,555
    182
    Model of Z:
    Z4 Coupe
    They are ok but at the limit of what I can tolerate visually. Will see how I get on with them.
    (Ebay: Xenon headlight RGB Multi-Colour LED Angel Eyes For BMW) £17.69
    Apoligies on the filth on my car.
    • Like Like x 1
  18. Aceman
    Aceman Moderator
    2,204
    707
    156
    Wakefield
    Model of Z:
    ///M Roadster
    Mmm see what you mean, your first pics of them at night also look too bright but not sure if that is the camera telling a lie. I suppose they operate better as DRL's for use through the day and switched off when you have the headlights on.
    How did the Mrs take to you using the oven btw :ymdevil:
    • Like Like x 1
  19. Lee
    Lee Zorg Guru (V)
    Mar 26, 2014
    2,839
    3,555
    182
    Model of Z:
    Z4 Coupe
    @Aceman She was not impressed =))
    The Halos are bright but you can adjust how bright with the remote and what shades of each colours, the options are almost endless.
    • Like Like x 1
Share This Page
