Running rough with intermittent limited power
Gilles
Hi everyone. Having a running issue with the z. When it's cold it runs roughly idling at around 600 rpm and feels as though it's going to cut out but rarely does. There is also a kind of wobbly sound in the tone of the exhaust. When it warms up it's like a different car. It feels like there is more power and the exhaust reverts back to a very smooth sound. It has started flipping between these 2 scenarios even when hot. I'm a bit new to all of this so any suggestions would be greatly welcomed.
NZ00Z3
New Zealand Zeds
Timaru, New Zealand
3.0L, 2.8L, 2.0L Z3 Roadsters
Which engine do you have in your car? The 4 cylinder M44 or a 6 cylinder?
Do you have access to a scanner? If so scan the car for trouble codes. Also let us know what the fuel trims are with a hot engine at idle. A 4 cylinder car will have a short term and a long term fuel trim. a 6 Cylinder car will have 2 short term and 2 long term fuel trims.
Many rough idle problems that change between cold and hot running are caused by vacuum leaks. Have a good look at the rubber boots between the Mass air low meter (MAF) and the inlet manifold for cracks or leaks.
Gilles
The issue is intermittent so can that still be because of vacuum leaks. Would it not idle roughly all the time. The car is a 1999 2 litre 6 cylinder.
Gilles
Sorry should have said that when warm it sometimes idles beautifully and sometimes idles really roughly
NZ00Z3
New Zealand Zeds
Timaru, New Zealand
When the car first starts, The engine computer (DME) runs in open loop mode. It uses in built fueling tables for the mixture. The O2 sensors are not used. When the engine heats up, it goes to closed loop mode, uses the O2 sensors to see what the level of oxygen is in the exhaust and trims the fuel to get the correct mixture.
A vacuum leak can cause rough idle when cold because there is unmetered air getting into the inlet and this upsets the mixture as open loop mode can't adjust for the extra air. When you get to closed loop mode the engine Computer (DME) uses the O2 sensors and can compensate for the extra unmetered air. If the vacuum leak gets really bad, the O2 sensors and DME can not compensate enough and the rough idle occurs on the hot engine.
NZ00Z3
New Zealand Zeds
Timaru, New Zealand
Gilles
Thanks so much for all the info! Its going to make getting used to this car a whole lot easier.
Woodsta888
Exmouth, Devon
I had an intermittent fault with rough running on my wife's 2.0. May not be the same but it's a cheap fix and my indy didn't find it after £400.
When you have the issue, undo the fuel cap to see if you get a rush of air.
If so there is a solinoid that saves the Z3's farts into a charcoal canister (petrol vapor). This failed on mine intermittently and so gave intermittent rough running.
2nd hand genuine OEM one off ebay, and a common part across many BMW's at least; ~£10
Gilles
So plugged in one reader and I have a misfire on cylinders 4,5 and 6. Any ideas?
Gilles
So the car had been sat for around 18 months before I bought it, only moving for an mot. Going to give it a full service and then go from there
Then warm it up nicely then take it for a long Italian tune I'd say.
