My 1999 Z3 2.5L sat for 6 years after the previous owners put in a replacement engine which I'm told did run.
It will start and rev smoothly to 1500-2000 rpm and then it acts like its starving for fuel and wont idle nor accelerate.
If I continuously romp on the pedal for a couple minutes the STFTs will increase from 0 to 27.3% and then idle and run.
LTFTs are at 0%. They started at .7 and 1.5 but after 60 miles they are at 0 and have not changed.
Shutting engine off normally results in same rough idle and no acceleration once again.
* At the moment, No error for DME Engine-throttle output-stage shutoff after diagnostic.
Only codes returned after 5 min of running:
Old gas purged
New fuel pump, fuel filter, fuel pressure regulator. At the rail she reads 50psi and delivers 16oz of fuel from the rail in 15 seconds.
Spark plugs cleaned
New CCV and hoses (wheeze from torn diaphragm is gone)
New Air intake boots
New MAF sensor
Throttle body cleaned including pedal position resistors
New idle control valve
(4) New O2 sensors
New vacuum lines to 1 way valve, secondary air pump, and pressure regulator
(6) New injectors,
Awaiting (6) new ignition coils
Diagnostic results:
All cylinders have 150psi compression. When kept running it will throw codes for miss-fire in all cylinders.
No response to spraying intake, hoses, etc. with carb cleaner.
Smoke test showed no air leaks.
DISA valve does not hold vacuum for more than 3-4 seconds but does move as idle gets rough.
12V at injector rail is good. (11.5V with 7Amp load)
Plugs came out black again after 60 miles of test driving.
Other notes:
Repaired ABS module, installed new front wheel speed sensors, and wear indicator.
TB was giving codes for stuck throttle and pedal position sensors but not now.
Secondary air pump does run at startup.
Entire car was underwater at some time before 6 years ago.
Prying Questions:
Why are LTFTs not updating? It sure seems that would help with restarting.
Other than brake booster, CCV or external leaks what other system could cause unmetered air to enter combustion chamber?
- P1188, P1189 for short term fuel trims at max
- P0150, P0130 for upstream O2 sensor readings too low.
Old gas purged
Spark plugs cleaned
New MAF sensor
(4) New O2 sensors
(6) New injectors,
Diagnostic results:
Other notes:
Prying Questions:
