Rough engine performance at low rpm...........
Discussion in 'General Car Stuff or non-Zed Specific Stuff' started by FRANKIE, Aug 30, 2014.
  1. FRANKIE
    FRANKIE Zorg Guru (V)
    American Zeds The M44 Massive
    Sep 2, 2013
    5,213
    3,382
    187
    Model of Z:
    This problem if not with my BMW but with my honda. It is a problem that could happen to any car so I thought I'd run it by you guys to see if anyone had experienced the same problem with one of their cars.
    When I start the car and drive it, everything operates well when the engine is cold. After it warms up, there is rough performance at lower rpms. While I can't rule out the rotor, cap, and wires, it just doesn't seem likely. My reasoning for this is that the car operates normally when cold. The rpm only breaks up at the lower end of the rpm range. At higher rpm's, I can really wind out the engine without it breaking up. Also, if I am very careful in EASING the gas petal during acceleration, there is no break-up at lower rpms. Could it be dirty injectors?
  2. Aceman
    Aceman Moderator
    British Zeds 3rd Party Trader
    2,204
    707
    156
    Wakefield
    Model of Z:
    ///M Roadster
    Hey Frankie how are you ?
    Hard to say without seeing it in person but I would hazard a guess at an air leak in the induction system somewhere. My reasoning is that at lower rpm the engine does not require as much air and if there is a split somewhere in an induction hose the ratio of metered air to unmetered air coming in through the split will be greater having a significantly greater effect on the fuel/air ratio than it does at higher rpm.
    So check all the rubber hoses going from the airbox and the smaller vacuum hoses leading of the manifold as I bet one is split or broken off somewhere.
    • Agree Agree x 2
    • Like Like x 1
  3. t-tony
    t-tony Zorg Expert (I)
    Supporter British Zeds
    30,217
    14,256
    220
    Model of Z:
    Z4 3.0 Auto
    If none of the above Frankie, I would try some fuel system cleaner just in case you have a sticky injector.
    • Like Like x 1
    • Agree Agree x 1
  4. oldcarman
    oldcarman Zorg Guru (V)
    Supporter Canadian Zeds The M44 Massive
    Feb 11, 2014
    9,986
    3,617
    177
    Pine Falls Manitoba can.
    Model of Z:
    In which case Frankie now knows how to deal with a sticky injector after being with Baaabs!!
  5. zedonist
    zedonist Guest
    It may have some rice husk stuck in the intake affecting air flow at low rpm?
    • Funny Funny x 3
  6. FRANKIE
    Sep 2, 2013
    5,213
    3,382
    187
    Model of Z:
  7. t-tony
    30,217
    14,256
    220
    Model of Z:
    Z4 3.0 Auto
    Just a P$ss take Frankie, we in the UK "used" to refer to Japanese motors as Riceburners.;)
  8. FRANKIE
    Sep 2, 2013
    5,213
    3,382
    187
    Model of Z:
    #8 FRANKIE, Aug 31, 2014
  9. zedonist
    zedonist Guest
    Too sausagey
  10. t-tony
    30,217
    14,256
    220
    Model of Z:
    Z4 3.0 Auto
    IF I still had a garage in Kissimmee instead of a games room Frankie, that is the type of car I would park in it. Looks gorgeous too, a Z really wouldn't be practical only because of the 2 seats. Shirl's car at home is the same configuration apart from being a folding tin top.
  11. David Cullen
    David Cullen Zorg Legend
    Supporter The M44 Massive
    Jul 8, 2014
    760
    366
    76
    Prosperous, County Kildare
    what Honda is it Frankie? year etc... did you do a cel check? could be vacuum leak or iacv
    • Agree Agree x 1
  12. FRANKIE
    Sep 2, 2013
    5,213
    3,382
    187
    Model of Z:
    Its a '94 Honda Del Sol 1.6 vtec dohc.
  13. David Cullen
    Jul 8, 2014
    760
    366
    76
    very cool man, you know how to do a cel check?
    View: https://www.youtube.com/watch?v=7bpwfiCxw54
    will be similar to any of the obd1 Hondas, find the two pin block under the dash and bridge it, follow the video above and it will tell you if any sensors are gone, its the first step you should do anyway, failing that id say it is a vacuum pipe, let us know how you get on :)
  14. Zeti
    Zeti Zorg Guru (III)
    Supporter Romanian Zeds The M44 Massive
    Oct 9, 2013
    2,436
    1,809
    141
    Bucuresti/ Romania
    Model of Z:
    Z3 roadster 1.9
    Hi Frankie,
    My suggestion is that the air sensor MAF should be the problem: dirty or dead! While the engine is cold , the system delivers rich mixture of gasoline , so you feel the engine running smooth; after the mixture come to the normal level is poor in gasoline and you get a bad running at the idle speed. It's just a guess, but it worth to check the MAF......
    • Agree Agree x 1
  15. David Cullen
    Jul 8, 2014
    760
    366
    76
    either way, if you do the cel check it will tell you whether it is maf, iacv or whatever
  16. zedonist
    zedonist Guest
    Might be brown rice, takes longer to cook......
    • Funny Funny x 2
  17. FRANKIE
    Sep 2, 2013
    5,213
    3,382
    187
    Model of Z:
    I have done this on several occasions in the past with good results. My check engine light is not on right now. Perhaps I should do it anyway. Thanks, Frankie
  18. zedonist
    zedonist Guest
    Might be a dirty injector, try running some Rice Wine through the fuel.........
  19. GazHyde
    GazHyde The Gaz Monkey
    Dec 2, 2011
    15,111
    9,173
    Newbury, Berkshire
    Model of Z:
    BMW Z4 3.0Si Sport
    I wish you would be a bit ricer to Frankie with his serious question, err, whoops... nicer... :ymdevil:
    • Funny Funny x 2
  20. zedonist
    zedonist Guest
    I have been, I got all these potential answers direcry off the ronda rivic site!
    • Funny Funny x 1
Share This Page
