Roof/window problem
rmoconnor41
I am having an issue whereby when I put the roof back up the edge of the roof slips out from the plastic strip that surrounds the window. I have been able to push it back under but the problem is worsening.
Is this a roof problem or window problem or both?
Thanks
NZ00Z3
New Zealand Zeds
Timaru, New Zealand
3.0L, 2.8L, 2.0L Z3 Roadsters
Its a bit of both.
The rubber is attached to the zip in window. It ages, starts to lose it shape and ultimately start to break away from the window.
You can see the threads from the top starting to fry a little bit.
At this stage, people start using all sorts of glues to try and fix the problem. It works for a while. If you are going to sell the car soon, then gluing may be a good option.
If you want to keep the car, It's time to think about fixing the rear window properly before you mess it up with glues.
Check the stitching around the window, those white/grey stitches. How many are missing? There is one missing in your photo. The ones to really look at the in the middle of the sides where the fold happens. Those stitches hold in the window zip. If needed they can be hand sewed with 2 needles, one inside and the other outside. Best done with the window removed.
As for the window, there are several options. Ones with a similar rubber bead and ones with a glue over flap. If the frying is not too bad, then a window with a rubber bead works well. If the frying is getting bad, then going to a window with a glue over flap works well. I just jump straight to the Glue over flap window in all cases.
I use the Emiata Z3 rear window. Have fitted 3 now. It has a thicker clear plastic window that lasts a long time and the glue over flap that seals very well and looks good. The product quality is great and it zips in well. The window kit even comes with the Zip pulls that you need to do the job. There is one in my 2.0L Z3, which has been there for over 10 years and still looks good.
rmoconnor41
Thanks for the comprehensive reply. I will take a look at the stitching tomorrow.
I intend to hang on to the car as I have been chipping away at the jobs.
Is that Z3 rear screen shipped from the states?
rmoconnor41
Its a bit of both.
If the stitching holds the zip how does the rear window come out?
NZ00Z3
New Zealand Zeds
Timaru, New Zealand
Just as the fly in your jeans has two sides, so does the zip that holds the rear window in.
One side is on the window
Other side is stitched to the top with those white/grey stitches.
Yes the Emiata ships from the USA, but it's cheap, ships quickly and works.
Hey, I'm deep down in the South Pacific and use them because they are so good.
rmoconnor41
Hi
Thanks. I went to bed then realised exactly how the two halves work
Thanks
Richard
