I’ve recently noticed a new rattle coming from inside the car, then sometimes the roof would not go down as it was getting snagged on something I couldn’t see. Turns out the two parts of the roof strut had come apart. The bottom parts with the shaft got wedged against a fixed metal part and just stayed like that. The top part that is attached to the roof frame is now dangling and catches on the shaft as you try to lower the roof, but it took a while to figure out what was happening because the strut is on the passenger side and it wasn’t catching every time. Presumably it’s an easy fix to unscrew the top section and attach it to the shaft again, but it’s not clear how it came off in the first place. Is there a lot of trim to remove to get to the fixing at the bottom of the shaft?
