my roof dosent seem to go down all the way, has anyone had this problem and suggest any issues which might cause this? haven't come across it on search :-/ thanks
Totally agree with Terry, however I think the frame has already been distorted and that is why you cannot lower the roof fully. I would check the roof frame around the area that the ram connects to the frame, this is located behind the passenger seat.Be careful guys. If you bypass the roof micro switch and then operate the pump without initially cranking the first section of the roof you will distort the whole mechanism. Then it won't fold properly.
