Ok, the summer gone an my roof dead. Interestingly, it is not 100% dead. It does go up, then stuck, then go another inch or so then stuck again, then go a little bit more and stuck and finally never close. I've operated it manually and managed to close the top. Called to nearest soft-top specialist and he told me this must be motor, which operates the pump. I am not 100% certain it is the motor, seems to me it could be something else as error read from the control module say: 1f switch cowl panel locked short circuit to ground. Any ideas?
