Wanted Rocker Gasket Bolt
Ryan
Manchester/Cheshire
Z3 2.2i Sport
Hello all. I recently changed the rocker gasket on my M54 engine. However, when putting it back together i snapped the first bolt that i tried to torque, so i just did the rest by hand. However i now need a new one.
Well actually 2, the bolt that attachs the Cap to the Cylinder head and the cap itself, both pictured below. It takes a 10mm socket to remove both and i'm hoping someone can supply??
stephen roe
View attachment 96235 View attachment 96236
Best bet is to ring your local BMW dealer , I broke one this week when replacing said cover gasket and again using a torque wrench (tighten by hand).
They we're about £10 Inc vat posted for the two bolts.Worth buying a couple of each just in case.
I can dig the part numbers out for you later if you need them.
