Rocker box gasket
Dalek
Highworth, Wiltshire
Z3 2.2i Auto
I am loosing a bit of oil from the rocker box gasket. Can someone talk me through how to change it?
Mazza
Bognor Regis
Assuming yours is a 6 pot....this is from Bentleys
When I did mine (only a 4 pot) I used some sealant all round, and you need to check that the half moon parts are located correctly at the back of the engine. They have a habit of moving when you put the cover down on them.
I also put sealant on the 4 spark plug seals, (yours has 6 ?).
Dalek
Z3 2.2i Auto
Thanks Malc,
Yes, mine is a 6 pot.
gookah
Shropshire
2.8 Z3
also the old gasket can go very brittle and leave parts of it still in place, especially the gasket around the spark plug holes. I put loads of tissue paper in around the plugs and the valves, and then scraped of the brittle parts and hoovered the bits that fell off into the paper,.
