TitanTim
- Joined
- Dec 7, 2011
- Points
- 43
Hi all,
Thought I would share some piccies of the Roadster Solutions wind deflector fitted today
The perspex is held in place by a pair of rubberised brackets held in position with 3M tape. I was a little dubious regarding this but after doing some searching of other owners fitting this deflector it seems upto the job and remains firm at speed. Install took 15 minutes, just making sure you clean the hoops thoroughly before attaching the brackets and doing it on a warm day 70F or above
Just need a steady hand to align each bracket and putting firm pressure for 30 secs or so. Was surprised how firm they are now. The perspex is a tightish fit which pushes down and locks into place, with it being a tight fit it helps keeping pressure on the brackets against the hoops.
Very pleased with the looks as errs on the side of an OEM install but after a drive well upto 40mph for the moment I can honestly say it doesn't make the slightest bit of difference to inside the cabin, :-\ haven't tried with the windows up at higher speeds so might be an improvement there
A few pics
Cheers,
Tim.
A few pics
Cheers,
Tim.
