Ok, a bit of a weird one.
With the soft top when you unclip it and lift it there is a small piece of sprung steel at the passenger side hinge (at the front) that holds that part open while you then press the button to lower the roof.
On mine the spring is no longer up to holding that part of the roof up so you have to hold it up and press the button. Does anyone know what that spring is or part number ? I've tried looking on realoem but couldn't see it.
Thanks
Thanks
