Silver Baz
About three weeks ago my E-Class threw up an engine light fault , the OBD2 check showed RH air intake sensor fault and so began a bit of a saga .
It's a 3 litre engine and all the YouTube vids showed people removing sensor and cleaning it or replacing if that didn't work . I just could not find the sensor , turns out my engine was newer (2012) and both right and left sensors are in the MASS Airflow manifold :
The sensor sockets are there left and right , easy except they are now built into the unit and can't be removed
. Doing a bit of research on forums and there were stories of £1500 for Mercedes to diagnose and replace , even worse reports of it not rectifying the fault . No part of this unit comes apart but a guy in the USA had used a heat gun to remove the sections holding the sensors and swap them around to see if the fault changed sides . So I set about this as I have a heat gun , had to reheat to get the flanges to reseal after the swap . Back on the car and sure enough the fault went from right to left , so ok I bought the part , £250 for a piece of plastic !
Either side of the intake bellows their are filters (not shown) these were semi blocked which tend to cause the sensor fault as oil is sucked out of the turbo , I cleaned them but decided to buy some new ones . Right , on fitting the unit the plugs wouldn't match up with the sockets
, my plugs are four pin , the sockets 5 pin , a 2015 modification
The seller excepted my return but didn't have a four pin unit , found a few but and this is a big but - £750 ! I decided to go to a local independent Benz outfit and ask about a quick fix , nope you need the unit and yes they are £750 for a piece of plastic tunneling with two £5 sensors , scandlous ! Back to ebay and I managed to source one for £550 .
