Thinking about winter work on the never-ending project that is the Z3!
Bringing this up for discussion to check the latest., I know at least @Delk and a couple of others have them fitted.
Riser 'kit'
Bushes to go with the kit
I've emailed revshift to find out of I ned just the kit or must I replace the bushes (I already have Powerflex purple in perfect condition in there..)
I'm going to raise the car by at least 10mm as the roads and speed bumps round here dictate it. I don't know how it will impact on track cornering but if it becomes a bit too 'rolly' I will look at beefier ARB's. Given I have BC racing 6 / 8 kg F/R I hope it won't be adversely affected by the increase in ride it. Will hurt my aero though(!)
My thinking that the 12mm riser kit plus 10-15mm suspension raise will help bring the camber down from around 4deg closer to 3 (I believe 2,5 is ideal) as well as correcting the toe - it is apparently the increase in toe out that makes it more skittish on bumpy roads and hammer the tyres, rather than the camber (conversely this makes it turn in very easily and can give an oversteer led balance in corners, which is awesome in the dry, but not so awesome on a wet Brands Hatch!)
If I'm still not happy then the weld in kit that allows proper correction will be next step but that requires proper welding skills (=£££).
Thoughts and experience welcome as always!
Riser 'kit'
12mm Differential Studs and Spacers - BMW E30 / E36 318ti / Z3
These studs and spacers mount the differential 12mm from the subframe. They are intended to be used with our 12mm offset subframe bushings for the BMW E30, E36 318ti, and Z3. When raising the subframe, the spacers allow the differential to mount in the stock location which maintains proper...
revshift.com
Rear Bushing Kit - BMW E36 318TI / Z3
This polyurethane rear bushing kit will fit the BMW E36 318TI and Z3. The kit includes: 1x differential bushing 2x subframe bushings with new top washers 4x trailing arm bushings Teflon prelube Lifetime warranty Please specify the hardness and the subframe bushing height. * The 12mm riser...
revshift.com
