Z s all done mechanicaly and body work,just needs a respray and new top, but which one first, I would hate to respray only to scratch it fitting the top, also hate to damage the top respraying. Doing it all myself, any advice please
You can remove the rubber seal that goes around the back which will give plenty of access to tape under that lip and then over the soft top. You can see the access below with the seal removed, this is what I did when I had mine painted.If you paint while the top is on, there will be a masking mark all the way around the back of the soft top where the soft rubber seal is located. With the top removed, you can mask under the metal lip and not have a visible masking mark.
I'd like to see it when you get it finished Derick.Umm thanks all your replies, I wish I asked the question before now,as I have had all the panels off for repair or renew all cleaned primed and under sealed,it took hours if not days to get all the gaps on the panels right and all new clips, so I don't relish taking them all off again, looks like a seal removal and a very carefully masking up job. Thanks again
