Resonance noise
Firefox116
Hamilton, Scotland
2.2i
Above 40 mph in 5th gear, taking the foot off the gas, there is a distinctive resonance coming from the front nearside. I can feel it too through the steering column. The noise is only noticeable at speeds above 40mph. Tyre pressures are fine. Any ideas ?
Could it be the front nearside hub bearing ? (I hope not).
Antm72
South Yorkshire
Are the lollipop bushs ok if worn the arm may sit hard and cause a vibration.
A wheel bearing would be noisy on or off the accelerator?
  • Like
Reactions: Lee
lucky jim
blaby
z3
for what is worth i had a brake piston sticking & not returning ( is the disk hot ) ?
As above and also your tracking could be out?
