replacing shocks and springs all round on 2.8 Z3
ALEC
Hi just joined and need advice on choosing replacement shocks and springs all round on my 2.8 Z3... what are the options any things to avoid ??
Welcome @ALEC,
What are you looking for with new springs and shocks? Are you looking to stay the same ride height or lower it?
Cheers, Gary
Hi and welcome Alec. My 2000 2.0 had K&W lowered suspension on when I bought it.
ALEC
comfort..... Im not interested in driving sporty. Historically Ive always gone with main dealer parts but in reality BMW dont make these parts so why pay way over the odds for what others can supply and fit cheaper. There are different manufacturers out there providing components that local 'quick fit' type shops can fit. but whats the different characteristics offered by different manufacturers ?
I just replaced my rear shocks with Sachs who make OEM components for BMW. Got them from Eurocarparts.
If you want something a bit more "premium" then Bilstein are generally well regarded by people on here too.
ALEC
do you know why they are highly regarded ? is it comfort ? how do you like you Sachs ? what is thereir charachteristics ?
I wouldn't describe it as a hard ride Alec but definitely I would say firm. After market replacement parts are made by manufacturers who make OE parts but not to the same spec I would suspect. I would get quotes from several sources and make a choice from mid to top range of price. HTH.
ALEC
thanks ;-)
Someone like @zedonist should be able to answer you when he sees I've tagged him ;). He's has switched to them.
I don't really have any comparison to give as the rear shocks on mine were completely knackered when removed, and probably had been for the 10k miles I've done since owning my current Z3. One of them would compress and not have enough pressure to push the rod back out. Car drives well enough now though!
ALEC
oh cool... Ive always been megga impressed with the drive of mine .... Ive had her for 12 years and done 60k in her... but right now the ride is just sooo painful lol... lots of work needs doing including I need to change the flex disc and probably next year a new clutch.. but I dont care ... shes worth it :)
Z
zedonist
Guest
The Bilsteins in my opinion are heads above Sachs, the ride is progressive and sharp, it is not harsh at all, and they soak the bumps up including speed humps. They come in different flavours, the B4 is an uprated OEM style shock similar to the Sachs unit, then you have the B6 and the B8 these are both the same with regards to performance, and are a performance shock, the B8 is shorter and meant for use with lowering springs, these are what I have fitted with Eibach 30mm lowering springs and they are a matched set as part of the B12 kit. After these there is the B14 kit which is a coilover kit. If you want OEM but improved performance then fit either Sachs super touring or the B4 dampers.
