Replacing seat bushes...help!
bombur
Porthcawl, Wales
Z3 1.9, Z4 E89 2.3
Ok so I have sorted the new bushes and put them into the kebab. However on the Left side (as you sit) the rail has come to far up and I cant get it passed the block with the bush in
also on the other one I cant get it to line up with the T50 hole. Its in the spindle at the other end, but is a bit out
I don't want to force anything so thought I would ask for guidance in first instance!
Im probably doing something stupid..
bombur
Porthcawl, Wales
Z3 1.9, Z4 E89 2.3
Ive done some brute force on the left one, hammer and screwdriver :nailbiting: .......got it out
bombur
Porthcawl, Wales
Z3 1.9, Z4 E89 2.3
out with old
In with new
So passenger seat working fine.
Went on to do the drivers seat and I cannot take of the rear bolt (door side) off, other side was fine. I don't have a 16mm socket to fit my breaker so will have to get one....unless there are any tips on getting a tight nut off =))
update...have sprayed a bit of penetrating oil around seam and will see if that helps tomorrow
Extractor sockets, they have fluted inners that grip the bolt/nut as its turned anticlockwise, works on rounded off bolts as well.
bombur
Porthcawl, Wales
Z3 1.9, Z4 E89 2.3
All done and even though drivers side wasn't too bad with the rocking what a difference when driving!
Here is one of the old bushes from drivers side...not bad, the other one was a mess
