Replacing DISA valve and need to know what sort of grease to use to seal it back up.
Wintermute
Milton Keynes
Z3 Roadster 1.9
As above, I'm replacing my DISA valve in my 19. Z3, and wanted to know what sort of grease I should apply when attaching the new unit. I have had red rubber grease recommend to me, but the smallest amount I can find to buy is 500g. Any ideas?
Many thanks!
Motor Factors used to sell this in small tubes. Might br worth a few phone calls.
Wintermute
Milton Keynes
Z3 Roadster 1.9
Thanks! So I take it you'd recommend using the red rubber grease, as my mechanic did? I've also had someone say that it'll be detrimental to the valve, but that was a fellow at euro car parts who sounded horrified by the fact that I would ever think of using it...
I guess you're just wanting to lubricate the "O" ring seal where it fits into the manifold? If so I would just use a smear of clean oil personally.
Wintermute
Milton Keynes
Z3 Roadster 1.9
I am indeed. I've really only started working on this car recently; I'm assuming by clean oil, you mean just engine oil?
Yes. All you want is for the "O" to slip into position without curling or testing.
I would wipe it out best you can.
mrscalex
I've just been looking at o ring replacement. I wanted to find the correct size for an M54. Which I have and is with me now.
I'm sure I read what the ideal lube is. I'll see if I can find out in my notes.
I had a whole load of useful info from the development thread on another forum of the M54 rebuild kit.
