My Z is 18 years and has advisories on its last mot for corrosion of the front steel brake pipes. I had a good look around the rear end of the car and there where brake lines in some places around the nearside wheel arch and above the diff where the integrity looked dubious. Hence my next challenge, could all of the rear fixed steel brake pipes be replaced with Kunifer having access to only a set of car ramps and axle stands? I searched the forums and found plenty of good general information on replacing brake lines generally and the tools required but nothing I could find to specific to guide me. Goods news is that it can be done. Having recently retired must admit I have the time to spend doing this hence scope eventually turned out to be:
View under car with new Kunifer lines installed, routing around the suspension chassis mount was awkward but having the old lines as templates saved the day.
The fuel carbon filter was unbolted and moved to the side to enable better access to old pipe removal and new pipe installation. Took a small while to fiddle the old line out
Used all of a 25ft roll of new kunifer brake pipe, most parts bought from ebay. Only part I had to buy from main dealer was the hard to flexible retaining clips as shown below, cost 85p each.
Completed replacement of brake lines for about £100.
- Overhaul all front and rear callipers, new seals and including painting of the calipers + new EBC pads.
- Renew all flexible hoses front and rear (6off).
- Replace all corroded steel pipework with Kunifer.
