Replacement horns with correct fitting?
Geoff Crispin
Somerset
Z3 3.0 & 3.0 sport
Z3's are fitted with 2 horns originally, but given where they are situated, they tend to corrode and fail over time. As this constitutes an MOT fail, the tendency is often to do a quick replacement of one horn to get the vehicle through the MOT test.
The car is in very good condition but the front bumper did have a few scratches, grill was just a bit of mesh held on with cable ties as all but one of the fixing pins had broken off and head lamp washer jet shrouds were both split. So who knows what would have happened to it. Geofg
2DunnsZ3
Canton USA
Z3 2.8 5 speed roadster
I just realized after being on here for several months and looking at 100's of Z3's, that most of them do not have the plastic pcs behind each wheel to catch dirt. we call them mud flaps.
Geoff Crispin
Somerset
Z3 3.0 & 3.0 sport
Mine has those as they were removed the other week when bumper removed for re spraying and from what i see its all clean and in good nick. Geoff
Geoff Crispin
Somerset
Z3 3.0 & 3.0 sport
Removed nearside wheel and arch cover to find that there was a horn there after all in a different position to offside but coveted in crud . Disconnected and removed connected up a replacement but not working also cleaned up connections on connector and got working replaced arch cover and wheel. Will clean up the one removed and see if it works
