Replacement Condenser air conditioning needed - advise needed
Twin Turbo
I need to replace my air conditioning,unit but there is an big difference in prices - any of these venders any good?
VAN WEZEL Condenser, air conditioning
NRF Condenser, air conditioning
PRASCO Condenser, air conditioning
Probably not much help as he has a Z3 ///M but I seem to remember @swamper buying a reconditioned unit from somewhere?
Mine was custom built....as they don't make them anymore...so for a Z4 you be better buying from the shelf
When you say A/C unit Q, which part are meaning? Compressor, Condenser ?
ps. Can you see the makers name on the original one?
Got my condenser off the shelf from BMW, not too expensive £214, but you will need to change the drier too and that will be expensive from BMW got one from Autodoc for £44 (BMW wanted close to £300 for the drier??) had it all installed by the BMW Indy in Gloucester and its been ice cold for the past year.
Why will I need a drier, as I have a hole in my condenser - from a stone hitting it.
If the system has become open to the air (as in holed and discharged) then the drier will become saturated and wont remove moisture from the system correctly once its repaired and recharged any decent AC specialist should advise you of this too.
