Replacement brake lines
Paul Rice
Doncaster
Z4 2.5
Drawing up my winter list, thinking about replacing brake lines for braided. Looking at M-Tec (same as discs) or coloured HEL.
Any recommendations please?
Got to have a look at my nearside rear which had an MOT advisory on a brake pipe this year, have been looking at these
also here
and here
Althulas
Banburyshire
M Roadster
I bought these as recommended by a few members on here. I have not go round to fitting them yet and they have gone up by a few quid since I bought them but they do look well made.
Jjim
Mansfield
1.9 Roadster
Got some HEL ones on my Z3 and happy with them.
I used these ones Paul,
Wezmoto. I used blue but it really doesn't matter cos you can't see them when the wheels are on.
Martin Sullivan
www.ZEDonist.com - ZED Parts
Cambridge, United Kingdom
3.0 Roadster
Paul Rice
Doncaster
Z4 2.5
Thanks Tony. Looks like these are the ones good price and although will not be seen Callipers going to red so will match
Paul Rice
Doncaster
Z4 2.5
What's the rear hoses like to fit @t-tony I notice theirs 4 in total at the rear?
Yes there are 4 on the rear Paul. Original fitment is 2 short hoses with a steel pipe between them. The stainless hoses feature 1 longer and 1 shorter hoses which eliminates the steel pipe.
Only issue I had was that the hoses needed a large washer to stop the hose going through the brackets on the car. I contact the seller and they sell they would get this sorted so you may not have this problem anyway. But, if you do it just needs some flat washers drilling out. If you find you do I can post you 6.
Paul Rice
Doncaster
Z4 2.5
Thanks Tony, top man.
The ones shown on their add shows 2 grommets on each pipe could these be for the brackets ILO washers?
Could be they push into the brackets and the hoses push into them? Wouldn’t be secure enough I don’t think though for MOT.
Paul Rice
Doncaster
Z4 2.5
Spring clippy thing, you talk my language Steve:thumbsup:
Paul Rice
Doncaster
Z4 2.5
Fitted the fronts today without a hitch, rears another story gave up after a while trying to get the old ones off, 17 years of rust etc. Will have another look at the weekend, no rush not going anywhere for the near future.
Be good to see some pictures of the rears. I have to do mine sooner or later, be interested in your before and after pictures.
Sounds like you might have to cut the pipe and graft a new length in with new fittings for the new hose connection.
Paul Rice
Doncaster
Z4 2.5
May be different on the Z4 replacement hoses should be a straight swop its just getting the brake lines un done
The ones I fitted on the rear were a pair, one longer than the other which did away with the short metal pipe between the rubber hoses @colb
Have a look on my progress thread.
Page3, #43
  • Like
Reactions: Lee
Looking good Paul:thumbsup:
Tony
