Hi Gents,
I have a year 2000 facelift Z3 with an M43B19 engine. My airbag module has died I think as warning light is displayed, have tried two different diagnostic scanners but neither of them can communicate with the module. Fuses are ok, I removed the centre console and unplugged the module, checked a few pins on the connecting plug with multimeter and I was getting 12v on some of the pins so unit has power.
My question is regarding compatibility of replacement part, and how critical the date range/part numbers are?
My airbag module has part number 65-77 8386192, date range 01 - 99.
Second hand these seem to be in limited supply and they are around the £200 mark.
I notice on ebay that airbag modules with part number 65-77 8374798 date range 01-98 are plentiful in supply for around £20.
I think from what I have seen on line I might have to pay someone to program my vin number into the replacement module anyway in order to get rid of the airbag warning light, so is there any reason why I can't use the cheaper of the two modules?
Given the date ranges are so close I would think the airbag set up in the two cars would probably be the same, so are they compatible?
If anyone has any knowledge or experience in the matter would appreciate any advice, thanks.
Pete
Pete
