Hello Everyone!
Wow a whole different world today when compared to a couple of months ago. Hope everyone is staying healthy.
I have a leak at the joint of the upper plastic coolant line (11531705210) and the heater hose (64218377673). Both are new after a complete cooling system update and intake manifold upgrade a few months ago. It is just dripping, only when running. I figured out the problem spot by following the heater hose to that joint with my hand (after moving wire harness out of the way). It is very tough to get a hand in there I'll tell you! I confirmed my suspicion with a wifi borescope. Shows leak are clearly but no way to know which hose/pipe it is. Maybe the o-ring in the rubber hose?
Has anyone ever managed to replace this heater hose without removing the intake manifold? I am loathe to take apart that manifold. My son suggested possibly removing the air intake from the front up to the plenum, unscrewing the motor mount nut and slightly lifting the motor - maybe get a couple of inches?
Any help appreciated! Thank you and be safe!!
