Need to replace mine and have been given a replacement but cant find any help/instructions. Can anyone give me some guidance please
My knob only comes off if you pull it..true fact.Yep did mine a few years back. Unscrew the gear knob. Gently squeeze the gaiter at the bottom to work one edge out and it'll just slide over the top of the gear stick. It's just situated with a few plastic clips attached to the gaiter. It's a 30 second job, no tools required.
Your right Hugh, sorry Geoff. Took a bit of doing as well now you've said that.My knob only comes off if you pull it..true fact.
mmmmmmm it's been some time since we had a knob pulling thread. But yes they all come off with a good pull, perhaps a little bit of twisting to start off with but do not unscrew especially if your knob lights up. You'll twist the wires round and round the gearstick.My knob only comes off if you pull it..true fact.
Just pinch it at the corners Geoff. Should come straight off.Just pulled the gearstick knob off this afternoon, it was easy this time, BUT cant see how the gaiter comes out, and then once it out cant be easy to feed back in ? or does the plastic cover all round lift off ?
Grumpy you said that once knob was off it was easy, what am I missing ?
No it's easyIs it as hard to get it back into place ?
