Removing plastic valance under the grill
Chaz Ricorn
Z4 3.0Si Sport
Hi can anyone advise me on how to remove the plastic valance at the front underneath the grill.
It looks like there are some catches at the top of valance I was wondering if I released those wether it ould then tilt forward ?
Also as you can see the fog lights have a lot of moisture in them, can these be removed ?
It looks as though that's the way to remove the grille mate. Water ingress into facelift fog lights is a common ailment. Not sure if you can't split them like Z3 headlights.
Chaz Ricorn
Z4 3.0Si Sport
Cheers Tony, would be nice to get them cleaned up as they look a bit naff as they are.
Paul Rice
Doncaster
Z4 2.5
The valance has lots of speed fasteners, Bumper off to gain access.
Ianmc
New Forest
Z3 (M44)
The fog lights should clear if you turn them on for a while:thumbsup:
lucky jim
blaby
z3
my fog lights are same not only moisture but it will have damaged the silvering the only thing i can think of is drill holes to ventilate to get rid of moisture ..ive put blue l.e.d. s in mine as the car is blue useless as fog lights
