Removing existing Exhaust tips (2.2, grey/black tips)
DivideBYZero
Surrey
Z3 2.2
So I bought a couple of OEM BMW Chrome exhaust tips, and I thought this would be a 2 minute job, yet like most car related 2 minute jobs, it has foxed me. The existing tips appear to riveted on? They just have a hole, where I would have dearly like to have found a flat-head screw, just like the new ones...
Can anyone give some advice?
Is there an Allen type grub screw in the hole?
DivideBYZero
Surrey
Z3 2.2
Nope, tried that with a 4mm allen key, no dice, too small and a 5mm was too large...
Do you posses an angle grinder which you can use a cutting disc on to slice down the side of the old tips?
DivideBYZero
Surrey
Z3 2.2
I don't, unfortunately. I may try prying the old tips away at the "grub screw" to see if it will loosen them a little so I can slip them off.
From memory there should be a screw through that hole, so if no screw I'd suggest they should slip off. May be coked on a little bit and need some positive force to move them.
Try tapping round the tips with a small hammer while supporting the opposite side of the pipes. Then using hammer and a flat ended drift try tapping the tips off the pipes.
Mine are the same. Couldn't see for looking:mad: I'll give the "gentle" tap method a go.
DivideBYZero
Surrey
Z3 2.2
I used a claw hammer to rip at the metal using man-strength. They came off with some tapping either side and from above and below. Along with more pulling and power. :D
Then as I put the second tip on, it started to f***ing rain. Thanks, weather. You suck.
Anyhow, it's done and they look great. :)
Now I see why your Allen keys wouldn't fit. They were Torx screws! Can see in the first picture.lol.
DivideBYZero
Surrey
Z3 2.2
No, Tony, the holes were empty, nothing fell out as I ripped them asunder. :D
My mistake, it certainly looks like a Torx screw in the top tip? Anyway, you're right about the weather mate. Oh those new tips look very nice, where did you get them please?
DivideBYZero
Surrey
Z3 2.2
I got them from the Official BMW eBay store. i've used them loads, very good service, great prices and plenty of Z3 parts.
Item link:
http://www.ebay.co.uk/itm/171798899623?_trksid=p2057872.m2749.l2649&ssPageName=STRK:MEBIDX:IT
Store link:
http://stores.ebay.co.uk/BMW-Direct-Store?_trksid=p2047675.l2563
pgunter
Winchester
2.2i Sport Zedshed Special
Wow is that each ? £61.80 for the pair. Think I will save a little more and get a replacement exhaust in stainless. They do look nice though @DivideBYZero nice job :thumbsup:
DivideBYZero
Surrey
Z3 2.2
Yep, £30 each, but they are original OEM parts, brand new. I saved on postage, only paid that once (TIP: use the eBay basket to save when buying multiples from one vendor).
