- Joined
- Dec 5, 2011
- Points
- 190
Well @Mint I hope this helps
Use a torx bit (twice) from the rear of the steering wheel, I used a 27, but a 30 might fit too.
Pull the airbag out forwards - the battery on the car was flat as a pancake, but might be safer to disconnect!
Use a 16mm socket and large bar to remove the central bolt.
Use a phillips screwdriver to remove the single plastic screw in the middle of the underside of the steering column and then jiggle until the 2 halves come apart.
Disconnect the 2 electric plug fittings.
Give the steering wheel a yank and move head out of way.
Sorry couldn't take any more pictures, I had my hands full!
@oldcarman recognise this?
