Remove glass from instrument cluster
Discussion in 'Z3 Roadster & Coupé' started by Cooper, May 15, 2014.
  1. Cooper
    Cooper Zorg Guru (IV)
    Supporter Australian Zeds
    Apr 17, 2014
    1,164
    751
    157
    Hobart Tasmania Australia
    Model of Z:
    3.0i 2001
    Hi,
    Tomorrow I will be removing the instrument cluster which looks quite easy. The reason for doing that is because I need to wipe down the back of the glass [plastic] as someone got it dirty and it looks horrible while looking at the spedo and such.
    Is there anything I need to be careful about or tips and tricks on removing the glass? Is this going to be easy or fiddly?
    Cooper
  2. t-tony
    t-tony Zorg Expert (I)
    31,084
    14,688
    220
    Model of Z:
    Z4 3.0 Auto
    Not too sure re removal mate but I would use such as camera lens wipes to clean the inside and outside of the plastic lenses.
    • Like Like x 1
  3. Cooper
    Apr 17, 2014
    1,164
    751
    157
    Model of Z:
    3.0i 2001
    UPDATE:
    I removed the instrument cluster and the black back to it [5 x additional screws] which holds all of the electronics . Unfortunately the dials are still attached to the face of the cluster and I could not figure out how to get them off safely so I left them there. I carefully inserted a small cloth only to discover that the damage is to the OUTSIDE of the cluster!
    Next Question: Is there a way to polish the outside of the plastic? It appears that someone sprayed some cleaner on there and it has clouded/slightly etched the plastic.
    Cooper
    • Funny Funny x 1
  4. oldcarman
    oldcarman Zorg Guru (V)
    Supporter Canadian Zeds The M44 Massive
    Feb 11, 2014
    9,986
    3,617
    177
    Pine Falls Manitoba can.
    Model of Z:
    I'd try the Polish for cleaning the plastic headlight lenses, macquire's would likely be best. If it'll restore those can't see why it wouldn't work for your purpose. Maybe contact Chris at Summit Detailing a forum sponsor. Go to the home page and scroll to the bottom sponsor ads. HTH, JIM
    • Like Like x 1
  5. TaffZee
    TaffZee Zorg Guru (V)
    2,082
    1,363
    183
    Near Llangollen North Wales
    Model of Z:
    Z4 3.0 SE
    If I remember correct you will need to split the enclosure, remove metal clips, heat up the edges, I used a hairdryer set to full, and then pull apart breaking the mastic seal, sounds horrific but a little patience and its an easy job, I put chrome bezels around my clock..
  6. Cooper
    Apr 17, 2014
    1,164
    751
    157
    Model of Z:
    3.0i 2001
    Thanks Taffzee, I suspect that the white framed gauge frame assembly [looking from behind once the black back has been split off] comes off somehow which should leave the housing holding the glass window in position, then split as per your advice. The problem is I cannot figure out how to remove the white frame even after scouring the internet for pix or vid of someone else doing it. I am the kind of guy who accidentally breaks things unnecessarily causing hundreds of dollars in damage so I am taking things carefully.
    I will ask if the macquire's stuff will work, I hope it does, to save me the extra work.
  7. TaffZee
    2,082
    1,363
    183
    Model of Z:
    Z4 3.0 SE
    It has been a while since I done it 4 years ago, cant help any more but I am sure if you are careful and gentle you will (as well the toothless budgie) succeed.
    • Like Like x 1
  8. t-tony
    31,084
    14,688
    220
    Model of Z:
    Z4 3.0 Auto
    Hey mate I use greygate plastic polish off ebay or amazon. Excellent product. Definitely will do the job.
    • Like Like x 2
  9. captain
    captain Regular Member
    South African Zeds
    Sep 19, 2012
    81
    24
    24
    Durban, South Africa
    Model of Z:
    Z3 Roadster 2.8i
    There are two or three tubes at the back if I remember correctly, look carefully about half way down you can see a plastic clip which you need to release a quarter of a turn. That will allow you to split it, hope this helps.
    • Like Like x 1
  10. Cooper
    Apr 17, 2014
    1,164
    751
    157
    Model of Z:
    3.0i 2001
    Thanks. I have bought some PlastX and will try that and report back.
  11. oldcarman
    Feb 11, 2014
    9,986
    3,617
    177
    Model of Z:
    Just a hint for all when polishing up dirty plastic lenses. My optical guy uses used dryer softener cloths to clean plastic optical lenses and it works great. Give it a try on your speedo and tach! JIM
    • Like Like x 1
  12. Cooper
    Apr 17, 2014
    1,164
    751
    157
    Model of Z:
    3.0i 2001
    Well, I removed the cluster and got the PlastX on to it. There is about a 80% improvement and is in acceptable condition but not as good as I would like it. The cleaning stuff used by the other owner has created some deeper etching [spots] are still there. In case you are wondering I suspect the cleaning stuff was Armourall used for the dash. Don't worry, I don't use it myself :). I also used a Q-tip and attempted some more precise and vigorous rubbing in all directions but I cannot totally remove the damage. :(
    I also used the PlastX on the rear wind shield which suffered bird strike [crap] while it was in transit from Qld to here. It did a marvellous job clearing that up.
    • Like Like x 1
  13. oldcarman
    Feb 11, 2014
    9,986
    3,617
    177
    Model of Z:
    Don't know how thick the lens is but you may be able to use a DA sander with a real fine paper with WD 40 for lube to take a bit off the damaged face and then re polish with jewellers rouge and a soft buffing wheel. Be careful not to apply too much pressure as it could burn and leave marks. Work slowly and gently just make sure a replacement is available before attempting. JIM
  14. vintage42
    vintage42 Dedicated Member
    Dec 24, 2013
    227
    66
    39
  15. Cooper
    Apr 17, 2014
    1,164
    751
    157
    Model of Z:
    3.0i 2001
    Thanks @vintage42 for the video link. It is good but the Z3 cluster pulls apart from the frame differently. Once the black back is off the guages are held in by a white semi flexible frame. I think that @captain revealed how they come off.
    • Agree Agree x 1
Share This Page
