Ok so what am I looking forCheck the boot loom (in before anyone else says it)
Ok will have a look. So even though locks centrally from key in door this would still be an issue. ?Check the the switch on the drivers slam door plate push the switch in with one hand and try remote with other hand it may be boot or passengers door or bonnet hope this helps
Broken wires in the boot loom where it passes through the plastic loop. Repairing my loom sorted my central locking. The central locking fuse kept blowing, presumably due to wires shorting in the boot loom. Have you checked the relevant fuse isn't blown?Ok so what am I looking for
I know this is an old post BUT how did you change the striker plate? Did the rear quarter need to come off?Open the drivers door you will see the striker plate on the door push in the switch see photoView attachment 173673
