What red bits? Snowing again today at the Shed.
Getting ready for the Doncaster Show.
Good coverage that mateWhat red bits? Snowing again today at the Shed.
View attachment 228283View attachment 228285
I put up a YouTube thread on here a few weeks ago Tony about this very thing, all foam guns induct the snowfoam mixture at a different rate and also the expansion ratio differs on most if not all. This means that the same mixture will give different results depending on the gun. One bottle may empty entirely whilst another will only use half a bottle even with the same original amount.It is Andy, I never managed it with the previous snow foam gun I had, but to be fair that could have been down to the product used and not the gun.
On a different gun that may draw the fluid up quicker you could use more but good going. I can get Bella and the Yeti in one bottle, ish.I did the oil burner and the Z on one bottle Andy. Mixed at a 3:7 ratio.
I thought the idea of using foam was that you don't need to use a sponge or similar just wash off with a power washer. Avoiding adding swirls with a sponge etc.Can not believe your car is ever mucky enough to need snow foam
I would've welcomed that yesterday mate. Was bloody hot.And there was a cool breeze blowing in from the west when I started washing the car...................
This is what I got Dave.What snowfoam are you using?
Might try some of that. I use autobrite magifoam at the moment, you can make it so thick it's like shaving foam. Pointless though as it's just for looks when its like that. A nice thin layer like you have does a better job. Sometimes I struggle with magifoam and find it doesn't get rid of a lot of dirt but I need to dial in the perfect dilution rate. The best I've found for cleaning it bilt hamber autofoam once you work out the correct ratio for your lance.
