Hi gents;
I have a 2000 Z3 with the M43B19 engine. Head gasket went recently, decided to do it myself due to silly price quoted by local garage.
All went ok seemed straightforward, car now runs fine but engine management warning light came on.
I read the code using my basic scanner - P0135 pre-cat o2 sensor.
I fitted a new sensor and cleared the code, but it came straight back after a short test drive.
I found a comment somewhere on line that said sometimes this fault code can actually be related to the engine coolant sensor?
My scan tool is pretty basic but I plugged it in to have a look at live data, and the temperature being recorded by the engine coolant sensor was minus 32 degrees...pretty sure that wasn't accurate! The temperature being recorded by the radiator coolant sensor appeared to be correct, it started off at 30 degrees and rose to 60ish whilst I was watching.
Just wondered if anyone else has come across this - did my coolant sensor die or have I not plugged something back in correctly whilst doing the head gasket job?
I do recall when I removed the lower part of the air intake manifold that there were two plugs hiding under there that were hidden from view and it's possible I may have stretched the wires I suppose when I lifted up the manifold to remove it without seeing them. I know one of these plugs is for the engine coolant sensor, and there was another round shaped plug fairly close to it........is that round one anything which may be a factor?
Any comment/advice would be much appreciated, thanks.
