1997 Z3 Roadster, M52 2.8L
So, I rebuilt the motor, all new gaskets, bolts, cleaned valves, etc. It ran just fine after the rebuild, then after it ran for about an hour, there are no signs of life when attempting to start. The starter got tested today and it tests fine. HELP! The only thing that I changed from when it was running to when it wont make any sound or attempt is, I changed the cam position sensor cause the old one got melted and was throwing a code. Yes I have tried with old and new sensors.
Info about the car:
-ECU is not original to the car, it has been re-flashed and EWS is disabled.
-Ignition cylinder has been replaced with a switch board and relay button (verified all in good order)
-I have 12V at the main starter post and 10V on the 'trigger' post when the ignition is on. I havent had a second set of hands to get a reading when attempting to start.
What have I missed? Where do I need to look to get it running?
Info about the car:
