Cheers mate but need OEMGSF have 47% off this weekend!
Thank you for the info it's for Martin for Christmas he doesn't have the correct ones on the rear of the coupe we have found one so farI had to buy a caliper recently and I've noticed that GSF have bumped prices up so that things aren't actually cheap after their discount.
ECP email me 30% every weekend now but they have bumped up their prices so that with the 30% they are only matching their own online retailer carpartsforless
I've discovered that calipers are best changed in pairs. I did one one and had an imbalance so had to the other.
If the Z3M caliper is a specific part with an M tax then it might be worth sending them off for a refurb. Many places can do you a custom paint job on them at the same time.
The rears can be more expensive for some reason - on the 2.8 the front caliper I got for £50 but the rears are £150!!
Thank you for the help tho mateIt was fronts he bought found the post
Ooooooh Shiney Bits is the thread title still dont know how to copy the thread links
They were recon exchange OEM fronts Stacey but still bloody expensive (but i think approx £100 less than brand new) and the rears are even worse (sorry) but cant remember off the top where I got them but will check the receipts if it will help?@Nodzed are you able to help pleaseeeee
Yes please can you check thank youThey were recon exchange OEM fronts Stacey but still bloody expensive (but i think approx £100 less than brand new) and the rears are even worse (sorry) but cant remember off the top where I got them but will check the receipts if it will help?
Thank you are they OEM?@BMBabe
Stacey I didnt think this was where I got them but from Euro Car Parts Uk Wembley
///M front Caliper's recon £115 each with a £23.99 sercharge returnable when your old caliper is returned to them. Not as bad as I thought, but I am sure the rears were a bit more expensive. Hope this helps.
N
Cheers I will call themI believe so but not new, refurbished ...... I would phone them direct to check because I'm not 100% sure and don't want to mislead you
