Rear window
Alang
Hi all
I'm new to z3s had mine for 6 weeks now and have
Noticed rear window peeling at edges
Could 1 of you z3 veterans give me advice on how to clean area and what's best to stick back down.
Thanks alan
jaguartvr
Very hard to repair, if you try and glue it, it will probably just pull away again. The worst part is the white stitching, the stitching that holds the zip rots with age. Once this happens the roof is on borrowed time, have a look for a good second hand one (Spurs) or a replacement (Croydon soft tops).
Your window looks to be very good, almost new, it could be that the previous owner has tried to fit a replacement which has resulted in the stitching failing.
Alang
Cheers for getting back to me
I'll have a look at what u have suggested
Does not leak so not to bothered at moment
Maybe a new roof is best will consider closer to better weather
Eddie Zedder
Megawatt Valley, Notts.
Z3 2.0
Definitely not an OEM window. Looks like a replacement from Emiata as they have a fabric surround.
