Rear window fabric dislodging
JeremyZ3
Hello,
I've just noticed that the fabric is coming away from the window surround, is there a prefered way to reinstall this?
many thanks in advance.
Jeremy
Aceman
Moderator
Wakefield
///M Roadster
If you find after tucking it in under the window bead it persistantly comes back out then running a thin bead of black silicone sealant will do the trick. This is best done with the roof unlatched to release the tension on the rear window and then left to dry before fastening it back up so a garage is handy.
Ragtop
Bexhill On Sea
This is a common problem, it has happened on both Zeds I have owned and the fix is as Aceman has said above.
Jonttt
Liverpool (UK)
///M S54
You can get the black silicon dealent off eBay or halfords and use a lolly stick to lift the rubber lip, push the fabric under and run a bead of silicon under.
With the roof open (2 inches is all you need to release the tension) the fabric should stay put whilst the silicon dries. You will need to leave it overnight to dry.
Its pretty common as the rubber gripper built into the rear window looses some of its grip over the years ;-)
Titan
Moderator
North North Yorkshire
sDrive35i
A credit card or similar is an effective tool to use ;)
Sent from m'iPhone using Tapatalk
JeremyZ3
Thank you very much for your replies and handy tips, I've got a stock of flexible credit card sized plastic blanks that will be ideal for the job.
cheers
Jeremy
Titan
Moderator
sDrive35i
The main trick is releasing the hood tension and allowing the sealant to dry before fastening it all back up again. :-bd
It's a job most easily done in summer if you can manage to wait :)
JeremyZ3
Thanks Terry,
She's garaged for the winter, so a summer job it is !
Cheers
Jeremy
Boysie
West Chiltington, West Sussex
M Roadster S50
Yep thats another silly job i need to do
When i bought it had come away and the
Stealer replace the rear window.
The was car only a couple of years old
As you say its a common fault
Clear or Black silcone?
Titan
Moderator
sDrive35i
I used black simply because if you get any oozing, the black is less visible.
However, if you have a tube of clear, you can still use it - just be more careful :-!
wonderloaf
Z3 2.2i Sport
cheers
Jeremy
Errr, hope you're not doing anything illegal with them! [-x
Z
zedonist
Guest
I used the clear bathroom varity as it has the fungacide in it and will not go mouldy, did it a year ago, with the credit card,, no problems since, mod as above works :-bd
JeremyZ3
Errr, hope you're not doing anything illegal with them! [-x[/quote]
No, and I'm a bit miffed with the inference that I might!
Jeremy
wonderloaf
Z3 2.2i Sport
Jeremy[/quote]
Sorry, didn't mean to offend...when you've finished with them send them over to me, might be able to find a use for them ;)
wonderloaf
Z3 2.2i Sport
For anyone from any of our Security Services that last post was a joke! :D
Jamezee
Peak District
2.2 sport
Over time the fabric of the roof does shrink and tends to pull away at the corners of the rear window, I ended up using a trimmer to sort my 'corner' out at hardly any expense :)
Trimmer was Pete Lenton tel 0161 485 2464 or 07768302428 based in Stockport, small outfit but produce quality work. :-bd
