I was changing the wheels over this morning and was a bit confused over some movement in the passenger side rear wheel.
I jacked the car up to remove the wheel and found that although the handbrake was on I could move the wheel a bit and get a metallic knock . ( movement direction as if trying to spin the wheel).
When I did the drivers side rear, no movement at all. Any ideas what this could be?
Also, when jacking up the car .....there is a worrying amount of creaking from .......springs/suspension/bushes???
Is this normal when raising the car?
