How To Guide Rear Trailing Arm Bushes: Does size matter???
MartinJ
I have just removed the old bushes from my 1.9. However have a slight issue. the new BMW bushes look slightly smaller than the old bush. Is it a case of size does matter or will they new bushes fit on pressing...? The part number taken form Real OEM before purchase was 33 32 9 058 822.
this is the old bush...
Should I be concerned about the difference in size or will the new ones fit on being pressed into place?
wonder now if i should have gone poly.. ? :) LOL.
Any suggestions, experience, support most gratefully received.
Chu346
The overall size looks the same. That is how mine looked before installation.
They are the same bush mate, they often look like this once removed.
MartinJ
thanks all for all your advice. Will be fitting them this weekend ,hopefully.. and making up a brake line.. this refit is taking ages .. 😲:rolleyes::eek:...
Fender2004
Durham
I’m sure it will be worth it when you are driving down the country roads? :coolsteer)
